Wackeldackel
- Jul 2, 2014
- Location
- Potsdam, former DDR / Kent, UK
- 1999 Mitsubishi L200, 1989 W124 300E manual LHD, 1993 W124 250D auto, 1980 508D
Hello, first post after 7 months of lurking! Currently not in the UK but I am an Englander in Germany, getting lots of stick about the football...
The question I would like to ask is, does anybody have any idea what this connector could be connected to? Currently it dangles loose just to the left of my brakelight switch, coming from the same bunch of cables that connect to the brakelight switch. My car has ASD so all three connections (2 piggybacking and one smaller single connector) are all present on the brakelight switch.
I would hazard a guess that it may be an earth of some description, as the earth to the instrument cluster is also fitted with this type of connector. It has an MB part number and star and as far as I can see it hasn't been spliced in afterwards, the brakelight switch cables and their wrapping around the bundle is all untouched.
I am not really built for grovelling around in the footwell so I would rather ask first then remove panels and insulation later! Plus it seems the panel under the steering column and around ignition barrel is a right royal PITA to remove.
Car is a LHD 1989 300E MoPf0 (pre-facelift). With ASD and heated seats and no air con.
