N/S engine mount C350 CDI
D
Deletedmember132049
Guest
Hi all,
Iv changed my o/s engine mount which was completely shot, very straight forward and simple to do so.
Assuming the driver side would also be in bad condition, but not much movement upon testing.
So will be changing this for peace of mind anyway.
Looking at the driver side mount it looks like either the exhaust needs to be dropped down or the sub frame?
Before I do this just wanted a heads up on the correct method/process or easiest way to do this.
The engine is a V6 3.0cdi 2010
Many Thanks
Cheers, the video is the one for the n/s which has been changed my mistake i labeled the thread incorrectly.
I did manage to change the o/s the dpf had to be removed in order to wedge the mount out was quite akward and took over an hour to do so. Massive difference with changing both mounts they both had failed but upon testing they did not seem too bad.
