HF2
- Aug 16, 2007
- Location
- London
- Lancia Delta HF Integrale 16v, Lancia Delta HF LS Turbo 16V, C240, C36 ///AMG
My ABS and brake warning lighs are constantly on, and also the parking brake light does not illuminate when the parking brake is applied.
Reading through the various threads where similar issues have been discussed the problem could be either the parking brake switch, brake pedal switch, OVP relay or even the ABS sensors.
Before I start pulling things apart I have a couple of questions:
1. If the brake pedal switch was faulty will the brake lights still light up when the brake pedal is depressed ?
2. Would a faulty parking brake switch cause the ABS not to work or are they separate issues ?
3. What's the best way to test the OVP relay ?
I have fitted new front pads as the old set were worn down to the metal (I blame the previous owner !). I have also fitted new rear disc's and pads as well as shoes expecting the warning lights to clear but no joy
