- Dec 29, 2013
- Location
- Kidderminster Worcestershire UK
- Mercedes W124 260E M103
Hi back again for more information.From day one this car as had a oil leak ,along with the water ,but i may have cured the water leak .So down to the problem i need help with .This oil leak is on the passengers side under the inlet manifold .Its above the sump line and not the oil sender ,even higher than that . Can i look for anything else other than head gasket.
