WDB124066
- Apr 17, 2009
- 1996 E320 Sportline Cabriolet x 2
Hopefully pretty good if the cap was the anode...!
Low running temp is more likely to be a dead thermostat, especially if it takes a fair time to reach 70ish as it should only take a couple of miles to reach 80° even in the depths of winterMy coolant hasn't been changes in a long time and I just keep adding if it dips at all- rarely. I notice she runs a bit cold most of the time- 70- in normal use. Therefore I suspect the coolant/water ratio is a bit off. Is it simple to draw and refill the system and if so could someone give me a brief idea of how to do this? Thanks in advance
