Parktronic fault (not sensor) FIXED
Discussion in 'Electronics' started by Davycc, Apr 23, 2017.
  1. Davycc
    Davycc Hardcore MB Enthusiast
    227
    Apr 5, 2017
    Antrim, Northern Ireland @woodgateair
    Car:
    2001 W203 C320 Elegance
    Like a few others I was getting an error warning from my drivers side front parktronic system (really annoying) would go off as soon as I reduced speed enough to engage it,guaranteed to happen within a few hundred yards . It would happen in dry or wet conditions so today I decided to jump in and try to fix it. I removed the bumper trim housing the sensors good link here
    Mercedes-Benz W203 Exterior Molding Replacement - (2001-2007) C230, C280, C350, C240, C320 | Pelican Parts DIY Maintenance Article
    I cleaned all 3 sensors and replaced them and refitted the trim, no joy.
    Next I swapped the passenger side sensors one by one to find the faulty one if possible. After swapping all three the fault was still the same on the drivers side.
    Assuming (dangerous I know) that it wasn't a sensor I had nosey around and saw rubbing marks on the metal bodywork behind the sensor housings where the loom had been rubbing. There's not a lot of play to check the loom but 2 of them were "flattened" slightly so I taped up the loom and taped over the metal bodywork as well, I would have used heat shrink but the sensor plugs prevented slipping the heat shrink over the loom.
    Just back in from driving and stopping, slowing down etc and all is good in the world again.
    I've attached a pics of the offenders.
    Maybe worth checking out if you have the same issue before buying replacement sensors.
    Davy
  2. b1g1an
    b1g1an Hardcore MB Enthusiast
    1,458
    Dec 12, 2012
    Norfolk
    Car:
    Thug in a silk dressing gown
    Good find, bet there's a lot out there like this or heading that way.
  3. OP
    OP
    Davycc
    227
    Apr 5, 2017
    Car:
    Back again
    Well I started getting false readouts again on the nearside front parktronic sensor. I had her put on STAR and it showed the outer sensor as faulty (all others sitting at a steady 255 but the outer dropping out)
    I came home and swapped the sensor with 3 different ones and still the same problem so I'm guessing shorting on the loom or the module failing.
    Can anyone direct me to the location of the module please as I'm thinking if I can re route new wires and splice into the loom near the module as that may rule out a short somewhere.
    Any other ideas really welcome.
    PS frustrating thing is that even when it goes off in error as soon as I approach an object it drops straight down to one orange bar then works perfectly.
  4. OP
    OP
    Davycc
    227
    Apr 5, 2017
    Car:
    Ok
    So it's got to the point I pulled the fuse for the Parktronic as it was doing my nut in. STAR pointed out the off side front sensor as faulty (replaced it no joy)
    Can anyone tell me if the parktronic module in a 2001 S500 is the same as a 2001 C320 ?
  5. l5foye
    l5foye Hardcore MB Enthusiast
    734
    Jun 16, 2003
    N.Ireland
    Car:
    ML 300CDI
    When you say you replaced the sensor, was this with a genuine MB one? The reason I ask is I encountered the same problem and it turned out the sensor was the wrong one.
  6. l5foye
    734
    Jun 16, 2003
    N.Ireland
    Car:
    ML 300CDI
    Sorry I meant to ask what is the MB part no for your sensors? I have a couple here which might (stress might) do.
  7. OP
    OP
    Davycc
    227
    Apr 5, 2017
    Car:
    Hi thanks for the reply. I swapped the faulty sensor with each of the 3 nearside ones and always got the same fault (offside) all the nearside worked ok each time.
    I'm thinking either the module or a break / short in the wiring is the issue. I can get access to a 2001 S500 module if I need it to rule that out firs befor tackling the wiring.
  8. OP
    OP
    Davycc
    227
    Apr 5, 2017
    Car:
    Parktronic module location w203
    Anyone know where the above is located as I have one I can try just need to find the flaming thing !
  9. OP
    OP
    Davycc
    227
    Apr 5, 2017
    Car:
    Finally found it
    Well I finally tracked the module down.
    For future ref in case anyone having parking sensor issues (quite common) the module is located behind the foot well on the passenger side.
    Pull back the carpet and you'll see foam sound insulation, slip it out of the holding clips on the bottm and you'll see a metal plate.
    There are 3 plastic nuts, one top left and 2 on the bottom, remove these and the panel can be lifted out.
    Typical I find it on a Sunday evening, too late to start anything.
Share This Page
