Hi
I am a new member having recently bought a ML320 CDi (W164).
All is good but the front left parking sensors do not work, hopefully someone can help!!
The lights go on with the ignition but do not respond to close objects, the local dealer checked for faults and they show as working but give no reading when anything approaches so I was advised to change all 3.
To save a bit of money I bought some after market replacements, part numbers match and they fit ok but the once fitted the display constantly reads as full lights as if something is close to the sensor. The 3 original sensors on the other side, which were fine, initially read correctly but will not then switch off after the object is removed.
I checked the electrical resistance on the pins and found that they the new sensors were considerably different to the originals, at the top end 1340 against 1650.
Can anyone advise, I am told they are compatible and part number matches but do all 6 front sensors need to be the same resistance or should that not make any difference?
Any other advice would be appreciated?
