Presure drop
french
Audi TT RS 2.5 , Zanussi Wd12: - LG Combi Multiwave - Swan 9 slice toaster with removable crumb tray
The airmatic pump is acting up , few weeks back it was saying taking to long to reach pressure(F/code) so I bought the new gasket & piston ring kit from Ebay...then it showed a code which was saying it was taking to long to release the air:doh: Then I did a test for vehicle height & it did not budge 67cm f, came out next day front was down to 40 & the red warning to low on! So I took the compressor off again , had a look at the P/ring looked OK, so put it back together , put on the the diag & its will not pump more than 6.75 into the tank, its meant to be approx 14, guess its a new pump but can't understand what is stopping it reaching pressure ? Checked all the wires/connectors etc all seem fine?
