Product Launch- Redline Water Wetter
EuroCarParts
Wembley, London
European
Redline Water Wetter is compatible with new or used antifreeze (including DEX-COOLTM and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems.
Benefits Include
Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20°
Superior heat transfer properties compared to glycol-based antifreeze
Improves heat transfer and reduces cylinder head temperature
Designed for use with all modern aluminum, cast iron, copper, brass and bronze cooling systems
Price: £15.18:bannana::bannana:
