jon.english68
Woo hoo, one thing that has bugged me ever since I bought my Coupe in January, its bugged me that the puddle lights in the doors don't work, well today I wired them up [emoji4] looking at the wiring diagram I could work out which wires at the door module to connect to to make the lamp illuminate when the door is open[emoji106] A65 is the door lock and in side it there is a door switch, it was just a case of connecting a wire to the switched wire and another to the power supply and then feed the wires to the door lamp, I then soldered the wires to the lamp and the wires st the door module and hay presto, the lamp illuminates with the door open and turns it off when the door is closed [emoji2]
