tristand
- Mar 15, 2013
- Location
- Dublin, Ireland
- E250 CDI Coupe(C207) Year 2009 & 500 SEC(C126.044)
Hoping that someone has seen this before. Went to look at a R107 SL recently.
Without putting it up on a ramp, I did as detailed an inspection as I could. When I pulled up the drivers side floor carpets I saw some rust around what I can only call a sensor positioned in the body behind the throttle.
Firstly, I'm wondering what this sensor type thing is?
It's obvious that it's the source of the corrosion and is/was some sort of seal failure.
From what can be seen from the photos, would this be a big job to fix, would it require cutting out the panel and welding in a new one?
Would this be costly?
Would this corrosion be an indicator of other problem spots on the car.
I've searched this site and googled this with no avail!
