r0b53
Evening All,
Having previously been given some excellent advise by Derek I have been able to get my soft top to release OK but the root of my problem is down to a damaged release cable which can not be adjusted correctly so have now sourced a new cable and clips from the local MB dealership.
Simple swap out I thought, but alas despite all the fiddling around and unbolting of the catches I could not get the old cable to release from the respective levers and did not feel comfortable cutting the old one out only to find that I couldn't fit the new one. Is there a special technique to releasing the cable from these levers or do they need to be cut off.
Iv'e attached a few images that hopefully shows the problem and any help or advise would be greatly appreciated.
Regards
Rob
Regards
Rob
