R129 brake line corrosion
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by demetrios, Feb 21, 2015.
  1. demetrios
    demetrios Hardcore MB Enthusiast
    145
    Jun 20, 2014
    stafford
    Car:
    R129 500SL
    Hi everyone
    The SL has been SORN since December for winter in a garage and is due service MOT and Tax when it comes out.
    Looked at previous MOT notes and it says there is corrosion on brake lines. Has anyone fitted Tarox ones?
    Mercedes 129 Series 500SL 5.0 From Years: 1989-1993 Tarox BRAKE LINE KITS 4 Line Kit
    Also after its MOT and Tax gonna take it to Andy Gayle for B service (£250+vat.
    Has anyone used andy Gayle in Birmingham for their merc?
  2. a111r
    a111r Hardcore MB Enthusiast
    1,131
    Aug 11, 2008
    North East London
    Car:
    S123 240TD, S210 320cdi, S202 250TD.
    I suspect it's the fixed steel lines that have corroded, rather than the hoses.
    If it's just mild surface corrosion, black Waxoyl is my solution.
  3. stwat
    stwat Hardcore MB Enthusiast
    2,991
    Jun 20, 2004
    Sheffield
    Car:
    1989 W126 300 SE
    I think they are just the flexible hoses.Surly corroded brake lines refers to the metal lines.
  4. G.P
    G.P Hardcore MB Enthusiast
    375
    Apr 29, 2012
    Car:
    Leon & Sprinter
    A wire brush and a tin of copper grease is your friend..
  5. OP
    OP
    demetrios
    145
    Jun 20, 2014
    stafford
    Car:
    R129 500SL
    So what are the part number for fixed steel lines?
    I'm not a diy guy not on the car,more like a demolition man so if its more than checking oil and fluid reservoirs I tend to leave alone :D
  6. a111r
    1,131
    Aug 11, 2008
    North East London
    Car:
    Err, you need to ask MB dealer, not me. :doh:
    But realistically, it may be better to get replacements made up to suit.
    'HTH'.
  7. millo777
    millo777 Hardcore MB Enthusiast
    1,200
    Mar 9, 2011
    Swansea, Dubai, Riyadh
    Car:
    1997 W140 S600L/2003 S211 320cdi
    It would be pointless buying the metal lines from the main dealer as they don't come pre formed anyway. They'd be selling you a coil of metal pipe of roughly the correct length.
    Any mechanic would be able to replace them for you, and probably use either copper or cupro nickel (cunifer), neither of which corrode like the steel lines Mercedes used at the factory.
  8. rf065
    rf065 Hardcore MB Enthusiast
    2,960
    Jun 8, 2007
    Grossbritannien
    Car:
    CLK 220CDi - SLC300 - C250d Estate 4 Matic & VFR 800Fi-1
    I thought they did & that is why the dealer needs to drop suspension & fuel tank etc to fit replacements, which explains the high cost. That was certainly the case for mine anyway.
    Russ
  9. sharps
    sharps New Member
    9
    Jan 1, 2015
    Car:
    1993 300SL-24
    Yes beware if you are getting brake lines made up by another garage... Make sure you get them to follow the original factory routing.
    I've seen some horrible bodges in the past that have cost to put right... Brake lines running over fuel tanks and dangerously close to suspension components...
Share This Page
