Random boiler question
Discussion in 'OT (OFF Topic) Forums' started by A250 Bennyboy, Jan 4, 2017.
  1. A250 Bennyboy
    A250 Bennyboy Hardcore MB Enthusiast
    862
    Mar 16, 2016
    Northwest UK
    Car:
    A Class A250 w176
    Hi all had a bit of bother with my boiler. Kept loosing presure and had to keep topping it up, called out the gas man and he unblocked and small pipe attached to a presure valve, it was full of sludge/gunk.
    When he'd fixed the problem I was advised to have it power flushed at a cost of £600/700 quid :eek:
    This was a quote from BG
    My question, is this a DIY jobbie if I can hire the gear and what is the stuff you put back into the system that stop it from getting sludge up again can't remember what it's called:confused:
    And would it be alot cheaper getting a plumber in to quote me :dk:
    Cheers Ben :thumb:
  2. Ted
    Ted Hardcore MB Enthusiast
    4,740
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    A209 CLK AMG Sport Convertible, Yamaha XVS 1100, Jeep Renegade
    Fernox iirc.
    Personally I wouldn't do it as the potential to ruin your floor/carpets is pretty high.
  3. AMGeed
    AMGeed Hardcore MB Enthusiast
    7,498
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    I had a quote from a local plumber of £140 to power flush my central heating system.
    As it turned out, I had a new boiler fitted and the system was just filled and emptied once then refilled using Fernox (Ted is correct) and a Magnaflow filter fitted that removes corrosion from the system as it passes through before reaching the boiler and pump again.
    OP, get a local plumber to quote you. Far cheaper than BG.
  4. Happytalk73
    Happytalk73 Hardcore MB Enthusiast
    3,509
    Sep 10, 2015
    South West Scotland
    Car:
    212 E220d Saloon.
    You can DIY but as Ted says, if you're not familiar with the process it can go wrong. :crazy:
    Lots of additives available and most of them do the job. £600-700 seems quite excessive but I guess it's to be expected with BG. :eek:
    Well worth doing but maybe try a recommended local heating engineer.
    Ant. :thumb:
    1 person likes this.
  5. KennyN
    KennyN Hardcore MB Enthusiast
    733
    Sep 21, 2014
    Paisley
    Car:
    CLS - Grand Edition
    I fitted one of the inline magnetic filters to our system and was amazed at the amount of sludge it has picked up over the last few months.
    I put the cleaner through the system for two weeks before i fitted the filter then flushed it through with fresh water via the filling loop , i then refilled the system with fresh water and some inhibitor and the radiators have not been as hot since the system was extended 12 years ago.
    One of the reasons i fitted the filter was that BG had been out to clear sludge from various parts of the boiler and informed me that if they were called out again to repair a similar (sludge) fault then the maint contract would not cover the repair as i had been advised to fit a filter after their first visit.
    Kenny
  6. Avnt
    Avnt Hardcore MB Enthusiast
    212
    Nov 28, 2015
    Car:
    C350cdi sport
    The difference between Bg doing the flush and some of the local plumbers is that bg will spend all day maybe longer ensuring the system is flushed full and if it requires reflush 5yrs down the line it is done foc. Yes its an expensive dirty job to have done but it does work. The filters will clear some of it but if the system is sludged heavily it'll not work alone. If its not to bad you can do the flush with chemicals and the water main
  7. c63chris
    c63chris Hardcore MB Enthusiast
    786
    Mar 14, 2012
    Sussex
    Car:
    SL63 + W205 C220d
    You can hire the kit and do it yourself. Not a difficult job. The key is to get the sludge removed and then make sure you have inhibitor in the water of the heating circuit or this will happen again. A magnetic filter helps keep the system clean as well. It's a shame but most heating companies do not do this as part of the annual service and explicitly exclude sludge and related failures from your cover. BG used to do it when I worked there but eye have cut it back to make the visit quicker. As a rule of thumb you won't pay more than them for stuff like installs and flushes. Use Checkatrade or recommendations and get a local supplier to do the work.
  8. zipdip
    zipdip Hardcore MB Enthusiast
    1,112
    Mar 5, 2015
    Essex
    Car:
    s320
    Well a power flush is usually carried out by a plumber with the right equipment,namely a large plastic bucket and a pump that can be reversed,what they do is shut down all your rads except one,then connecting the two pipes of the pump to your system they force fluid back and forth around each rad in turn,you can see the crud building up in the plastic bucket,any price below £200 is a good one,it would seem you have a combi boiler to add inhibitor to the system is easy if you have one of the ladder chrome bathroom rads,just switch the boiler off and drain some of the rad down then remove the air bleed fitting at the top of the rad and pour the inhibitor in replace air bleed and re fill boiler.
  9. Chrishazle
    Chrishazle Hardcore MB Enthusiast
    2,127
    Nov 13, 2008
    Nr Ashford, Kent
    Car:
    2008 S204 C220CDI Elegance Estate Auto, 1993 Porsche 968 Tip Cab.
    2 versions of sludge clearance :
    Magnacleanse - double filter installed on the return line just before the boiler (piping modification required to allow subsequent installation of a Magnaclean filter). Uses the CH pump plus cleanser, one radiator at a time, plus an SDS hammer drill on hammer only and with their special pad tool to vibrate each radiator and get the sludge moving.
    Pressure wash cleaning - again probably piping modification required for later filter installation, uses an external pump working at much higher pressure and volume than the CH pump to do the job. IMHO this would be better, but is possibly more expensive.
    I've just had our 13 year old system Magnacleansed and a Magnaclean filter installed as part of replacing the boiler. After the job, the water that came out was clean (and the muck that came out each time he cleaned the Magnacleanse filter was amazing). I have not yet opened the Magnaclean filter, but bleeding radiators I'm still getting some black water.
  10. artyman
    artyman Hardcore MB Enthusiast
    1,656
    Mar 4, 2011
    Hampshire
    Car:
    C 200 CDI Sport
    I had a Magnaclean filter fitted a while back when my boiler started giving problems, amazing amount of sludge captured, brilliant piece of kit.
  11. developer
    developer Hardcore MB Enthusiast
    8,155
    Dec 28, 2007
    Car:
    S212 E63 S
    Before "power flushing" you need to decide how much you want this sludge to be moving around your system and towards your pump.
    Magna by all means, to remove the circulating sludge, but stirring up rads full of currently dormant sludge isn't the panacea it might at first seem.
    A few years ago I asked our plumber's merchant about powerflushes - his advice was not to, saying disturbing the sediment was to the detriment of the boiler.
    Another option, albeit more time consuming, is to remove the rads and flush them through away from the system - makes better sense if you think about it.
  12. Darrell
    Darrell Hardcore MB Enthusiast
    1,778
    Dec 15, 2006
    Back in Mill Hill but sometimes in Skiathos
    Car:
    A Jaaaaag, 2016 Dacia Duster and a 2004 Carrera (996)
    As the man says.
  13. zipdip
    1,112
    Mar 5, 2015
    Essex
    Car:
    s320
    Well if the rads are ages old then think about changing them,problem is if they are very old they will be a different size to new ones and so then you need to extend or shorten pipe work,around here most homes have micro bore pipe that is 8mm,which is fine as long as you keep a system clean,having had a new combi boiler fitted two months ago in my bungalow which I bought quiet recently,I also changed 6 out of the 8 rads,the other two will get changed when the new kitchen is fitted and and the lounge extension starts I also have a Magna fitted also a limescale filter on the water inlet.
  14. brucemillar
    brucemillar Hardcore MB Enthusiast
    6,492
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    I like the idea of this. Thank you. If I take a rad out side to flush it? Is it best to fill it with a solvent type flush to and leave it standing fort some time before actually hosing through? My rads are as old as the house and I suspect never been flushed in thirty years.
  15. Darrell
    1,778
    Dec 15, 2006
    Car:
    Never worked in a house with micro bore. In 33 years!
  16. alzieboy
    alzieboy Hardcore MB Enthusiast
    550
    Nov 2, 2013
    Car:
    E350CDI sport Coupe / VW Golf 2.0 GT TDi
    I used to just connect the garden hose to one of the radiator tails and just flush it out (once you have REMOVED the radiator to the garden of course ) :D
  17. OP
    OP
    A250 Bennyboy
    862
    Mar 16, 2016
    Northwest UK
    Car:
    A Class A250 w176
    Thanks guys for all the replys and help much appreciated cheers.
    I'll take your advice and get a local plumber in to do the job.
    And thanks for the heads up on a magna flow filter will also get one of these installed as well.
    Think I have created my own problems by having a new boiler fitted with the old rads from the previous boiler.
    Good idea about flushing them by removing, might have a look at doing this.
    Once again thank you all for your help :thumb:
    2 people like this.
  18. developer
    8,155
    Dec 28, 2007
    Car:
    S212 E63 S
    Dunno mate - I've never flushed a rad - as I worked through my house, room by room, I just replaced the rads as I went - they were all old/inefficient.
    None had failed, but it was sensible whilst floors were up etc.
  19. alzieboy
    550
    Nov 2, 2013
    Car:
    I work in one on a daily basis, my house built by Wimpey in 2002 which incorporates the Boilermate 2 heatstore system , now that is a can of worms :(
  20. Peter103
    Peter103 Hardcore MB Enthusiast
    464
    Sep 23, 2012
    Car:
    E 350 Bluetec 9 G Coupe.
    Microbore heating systems will have a multi connection manifold ,on a conventional system usually sited in the airing cupboard, or sometimes under the floorboards, each Rad is fed off this, and this is where mostly the sludge would build, in the past the the best way was to cut it out, either take it outside and clean , or buy a new one.when refitting be careful not to get your connections mixed up, best to call a Plumber first. ;)
Share This Page
