Hi all, hopefully this is something simple.
My 51 plate C220 CDi automatic has recently developed this issue. It is pure luck whether the rear indicators and lights come on - the front set are all fine.
Sometimes the indicators flash when the car is unlocked using the key fob, and other times not. When dark/low level light the rear lights will come on as normal at the same time as the indicators when they do decide to operate, otherwise not.
I cannot see any corrosion in the rear light clusters including the multi wire connectors and bulbs appear fine. I'm hoping this may be a a common issue with a cost effective solution as just resolved the very laggy acceleration and kick down by cleaning the MAF sensor and changing the air filter.
Hope someone can help.
