I'm attempting to remove the headliner from the underside of the sunroof. So far, I've found two guides:
I don't even understand how it would work, anyway; the liner is prevented from moving downwards by the lip of the sunroof aperture on either side.
Any ideas?
but for the life of me I can't see how the clips come undone. The liner is stiff steel; even if I pull down hard on the front edge as instructed, nothing happens. I've tried putting a flat-bladed screwdriver beside the clips and twisting, but they don't budge.W124 Headliner Replacement Photos - PeachParts Mercedes ShopForum
"First step is to open the sunroof half-way. Then carefully tug downward on the front edge of the inner-panel of the sunroof (don't pull carelessly and bend it), there are four "christmas tree" clips holding it to the sunroof steel panel.
Once un-clipped, you can slide the inner panel forward. Open the sunroof the rest of the way, slide the inner panel forward until you can slide it up and out of the opening."
http://w124-zone.com/downloads/MB CD/W124/w124CD2/Program/Chassis/77-050.pdf
"Unclip sun roof heading at fron with sun roof 3/4 open (4 clips)"
Any ideas?
