forrester123
My '03 E320 had bad corrosion on the top half of the headlight lenses.
After looking at several remedies on You Tube, I decided to have a go.
First used 600 W & D using plenty of water, then next 1200 w/d, using lots of elbow grease.
I was a bit worried that the lenses were now completely cloudy!
Next step was to use a rubbing compound [ I used baking soda & vinegar ], again with plenty of effort. Keep wiping down using a water spray. Looking good, but still needed work.
Finished off with T-Cut & hey presto clear headlight lenses!
May need a sealer to stop it oxidizing again.
