Hi all!
I had a few questions about the lowering module i am hoping someone can answer. I have just had the module fitted on my SL55 and wanted to know the following, as the instructions aren't very detailed at all...
1) When I set each individual suspension the same value, say for example -30mm, I notice the car is not evenly balanced. Is it 'normal' to have one corner at say -20mm and the other at -40mm or should it be the same all round?
2) How does the speed limiter work? There is 'half way' and 'full way'. What does this mean?
3) Finally, when I switch off the car, i'm sure the car drops even lower. Is this normal? Will it go back to the programmed values once you restart the car?
Thanks, Sandeep
Thanks, Sandeep
