Replacement of Bonnet Emblem
Max Shine
East Sussex
E Class
I am looking at replacing the bonnet star with a badge but am unable to find a 44mm badge?
Can anyone point me in the right direction?
I may be wrong but I think standard is 57mm it's larger than the star emblem if this helps
The Star on mine is measured at 44mm
so to replace with a flat badge is what I am after
Yea I think the under part of the flat is 44mm to fit the dip then the outer side wider I will take mine out tomorrow and measure it if no1 has better intake this way we can check
That's very kind of you - thank you very much indeed
Just done this same thing, it's 57mm as Danny said, I looked for a 44mm but never found one.
So the diameter of the hole in the bonnet to accept the badge matches the diameter of the 57mm badge bit that fits the hole?
If you look at the pic Danny put up.
The black bit is the 44mm and that clips into the hole, then the silver part is the 57mm bit... Does that make sense?
Lee
It does indeed. Thanks Guys for the help and your time
Well, I read the tea leaves n my cup..... , haha
I am called Lee and I was just putting on the end of the post ..!
Nice to. Meet you Lee
Oh right! haha. Well Max is my stage name and my real name is a secret so don't tell anyone. But thanks Lee
I had read it doesn't sit flush - do you have a front view?
Thanks Lee. Appreciated.
