Andy67
Advice Need to replace these drop links on this car, got to say i have never had the car on axle stands before, so much of a novice on doing this.
Started to do this work today i brought the links from euro carparts and got the Lemforder make for this car and a 16mm and 7 mm spanners.
I put wheels chocks at rear and jacked it up, and put the axle stand under one of the suspension arms as in photo i did have it on the other Bigger arm at some point,, and jacked the other side of the ground. My question is two fold is the axle stand on a suitable place to do this work as I know i have to release tension on the suspension (roll bar ) to get the link arm to fit in easier.
my other question is in the last two photo,, with o/s wheel off i can see a part that is broken and don't know what it is. bit of a half moon shaped item with a swinging arm on it and a electronic plug fitted too it, want of a better word...
Didnt get the work done today as the arm that's fitted seem to want a 17mm and 8 mm spanner,, and the new parts are 16 and 7 mm.
cheers for looking
cheers for looking
