Is it possible to retrofit COMAND NTG 2.5, LCD cluster and the multifunction steering wheel in a 2009 MB Sprinter?
Yes., much easier if you have the correct cluster and airbag and of course contact spiral for your vehicle. Some extra wiring is needed. (remembering NTG2.5 came in MY2010 on sprinter).
A new cluster is easiest, if you have a used cluster you need to send to someone like cluster repairs to get it set back to "factory" so it can be coded for the new vehicle. The vehicle's datacard needs updating for the new options and it needs CODING, having noted down the service info (and mileage in KM) so it can be put back into the new cluster
Richard
Dunno of anyone in scotland. We have a number of people driving from far off places (much further than Scotland) to do this kind of thing.
The COMAND is correct.
If you can get the part number of the airbag and the cluster, and the VIN of your vehicle, I can check. It is *probably* OK.
R
I will PM you the info as soon as soon as I get it. Also would it be possible to install a reversing camera and linguatronic?
I take it this is the correct wiring needed to retrofit COMAND? LINK
and roughly how long would it take you to retrofit all these ?
Many thanks for your help.
Linguatronic can be fitted to viano but not a sprinter.
If you have audio-5 then its a different kit. Send your VIN to us and we can advise.
NTG 2.5 in the car takes about 60 minutes including coding. Linguatronic another 45 minutes roughly.
I have asked about the gateway and go no answers.
The ntg2.5 will work no problems there it's the set up is the problem if they cannot find it on star, the guys at comand on line had to turn on my rear view camera as my MB dealers did the data card but then could not find it.
I am going to fit MB dab and I am not sure again my dealers will be able to code it, this is why I ask should I get one fitted for next time.
