steve_bcs said:The part number for a new one is A 163 820 1575
Where on the dash have you mounted your present antenna.
to get 0 satellites suggests either its not pluged in , its broken, or you have mounted it underneath metal, or it does not have a clear view of the sky.
GPS antenna rarely fail in my experience.
dalbisla said:Steve,
I have only justed fitted the command and bought it from Steve MBenzNL. from day one (1 week fitted) it has only shown 0 sats. I have tried holding aerial outside place on dash etc still only shows o sats. Work okayish in day in night totally not working hence decided to go for roof mount. I did have it mounted underneath dash on plastic behind the glove box.
Also please advise 4th day today and sat nav command was making whinig noise for about 2-3 minutes
any help really appreciated
Dal
steve_bcs said:Must be a faulty comand then, If you are sure its not the antenna I had a comand that suddenly stopped showing sats from Steve and sent it back & he replaced it no questions.
I'd probably try another antenna just to be absoltely sure & if you still have trouble, just tell Steve & ask for a replacement. he's an ok guy and will look after you.
