Sl R129 hardtop
lars-mad
nearby Oslo in Norway
1996 c180 2.0 1995 C180 AMG 1988 190e 2.3 1989 230CE with facelift
Hi does anyone know if hardtop from a 1998 model sl fits on a 1993 model sl320
The seals are different, but the roof will fit.
I think from 95/96 on, the door windows slotted into a grooved channel for a more airtight fit, which meant the windows automatically dropping or raising slightly to fit in when the doors are open or closed. The older, fixed window design means that the window butts up against the seal, which doesn't have this channel. The problem you will have is that the window will push its way past the outer lip of the channel of a newer roof, so a constant obstruction, unless you drop the window manually first.
It may be an idea to get a price for replacement seals, if compatible, but I've heard they are a swine to fit if so.
should do, if u have problems have an older model hard top s friend is selling
Or make it a road trip and come over to pick it up?
