ZR already fitted, thought the 55 was capable of more than that ?
Yes it would be done with Developer mode (VMAX). It's not technically a delete limiter, the setting is just changed to a different max top speed.
Unless you mean the top speed of a standard SL55?
I would guess in the 190s with long enough run way.
Has a standard SL55 / E55K ever been known to hit 200mph?
Don't think so , it took Matt a 2 mile run on the autobahn and a map to 670bhp in his cl65 to hit the double ton.
Well, the Alpina B5S (blown V8) is running at 530BHP / 700NM (iirc) and those are in the 190s as standard (194mph I think).
However, given the air is quite thick at that speed - what feels like "loads left" may run out quite quick.
Saying that, mine as standard running 173mph at Vmax felt like it had a lot left.
Need more room than 2 miles though...
