Slk320 r170 main beam problem
Discussion in 'Electronics' started by mickytbird, May 25, 2012.
  1. mickytbird
    mickytbird New Member
    4
    Jul 30, 2011
    Car:
    slk320
    I hope you guys can help, The problem is that the main beam lamps work when the light stalk is pulled to flash, however when pushed nothing.
    I have read in another forum that it could be a relay, the main light switch or the stalk.
    Has anyone had any experience of this as any input would help before delvin in to the unknown
  2. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Over here, sometimes over there
    Car:
    1994 Mercedes C180 classic
    Welcome to the forum.
    Now with regards to your problem. What other symptoms does the car have? Do the indicators work and the wipers? Have you checked the fuses as well as the relay?
  3. Ted
    Ted Hardcore MB Enthusiast
    4,737
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    A209 CLK AMG Sport Convertible, Yamaha XVS 1100, Jeep Renegade
    If dip beam works and main beam flash does it is probably the switch.
    Try 'wiggling' the switch in the main beam postion, also move it up and down as if indicating left and right.
    If the main beam flashes, it is the switch.
    If you need to test the switch, I think it is a yellow wire for dip and a white wire for main beam. Test with a testlight.
  4. OP
    OP
    mickytbird
    4
    Jul 30, 2011
    Car:
    slk320
    Thanks, Wipers and indicators work fine. I was working on the theory that the fuse is ok as the flash works ok also same for the relay.
    Would they be different circuits ?
    Oh i wish i had a wiring diagram.
  5. OP
    OP
    mickytbird
    4
    Jul 30, 2011
    Car:
    slk320
    Hi Ted.
    Yes tried wiggling the switch for ages but nothing.
  6. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    It may be a connection on the stalk that might have worked itself loose. If you remove the cowling under the steering column, you should be able to see the connection there.
  7. Dec
    Dec Hardcore MB Enthusiast
    3,992
    Jul 28, 2004
    Car:
    C180,A. September '97 48k
    The outside lights need to be turned to dipped beam for the main/high beam to work, I know this is obvious but the car may be new to you and you may not realise this.
    Dec
  8. OP
    OP
    mickytbird
    4
    Jul 30, 2011
    Car:
    slk320
    Thanks Dec, quite used to the car as have had it some time now, All fuses are ok I do not know where to find the relay for the main beam However i would have thought it would be ok as the Flash works Fine,
    Tried wiggling the Main lighting switch from behind and still nothing, Next step i guess is to pull the Stalk switch out and hopefully test it out with a meter.
    Thanks ted for the mention of the wiring colours, However does anyone know were to view the wiring diagram for this circuit ?
    Thanks to all and will keep you informed.
  9. Ted
    4,737
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    Don't use a meter. Use a test light :)
Share This Page
