RossCormack
- Sep 21, 2009
Hope one of you gents can shed light on this problem. I am trying to test a 220 engine from a 1964 220SE w111. I'm using the electrics from another old Merc to supply the spark. So, I've basically wired up the starter and coil from the other car.
I find that I can see a spark on the plugs when I turn the key to position one then turn off - spark seen when I turn off, as expected. I see the spark when I turn the engine to line up the ignition distributor rotor to the corresponding lead to that plug.
What I don't understand is that when I crank the engine round by the starter motor, I see no spark. I would expect a spark every time the rotor comes round and then breaks away from its contact at the distributor. I tried cleaning the rotor and distributor cap but no change. Am I stupid to think I should see this spark? I just would like to see the engine fire. Any advice would be hugely appreciated, thanks in advance
