Dee James
My 2003 ML270 has a double din JVC aftermarket stereo and every now and then the 10 amp fuse blows - any ideas?
Its not wired correctly, as you say it should have a switched feed to power on/off and a perm feed for the memory. What is the rated amp's of the HU and what else is sharing that live feed?
Just had a look at the manual for my DNX9280BT, its rated at max 15amp so a 10amp would not work for me. Check your manual.
Does it blow only when you turn it up really loud (thereby using lots more power) or is it just random?
If interior lights on same circuit, does it blow when you open the door with stereo on?
May help narrow down when it actually happens?
Neil
Firstly, don't just put a bigger fuse than the wiring in or it will melt the wiring instead.
Someone hasn't bothered to run a switched feed (newer ML possibly have no switched feed on the power block) or has the switched and permanent backwards. Sort this out first and the problem may well go away as I thought radio feed was 15A (but its years since I looked on W163 ML)
I don't know whether a JVC unit tries to take its amp power from the switched or permanent feeds , but as the unit is around 4x50W it will be quite capable of drawing more than 10Amps(~120W)
Cheers
Richard
