Hi guys,
Big hello to everyone as it's my very first time here.
I have just bought w210 320cDi with 90k on the clock.
Only 1 owner car and it's a mint apart for one problem "black death".
Last owner explained to me that injector 3 is stuck as he tried to get it fixed but the mechanic couldn't do it so he decided to sell it. He was quite old guy and you could tell he wasnt interested in the car anymore. (Mechanic was mobile mechanic & that explains).
When I inspected the car. Injector 3&4 had worst case of black death. Literally covered with black stuff. Even worst thing was both injectors had 12mm strange looking normal bolts instead of the 6m stretch bolts. Engine would start without any problem but brownish smoke which could cover the whole street within minutes. Car was not safe to drive so I decided to call mate of mine. He's aa mechanic. We both came to conclusion that smoke is unburnt fuel (diesel) as it wasn't blue/white or black and no evidence of mixture of oil and coolant anywhere. And towed the car home.
I started taking the injectors out this morning. All injectors came out with a bit of struggle but injector 3&4 won't move the slightest. The trouble is I can not run the engine prior to take the injectors out as it smokes really bad. Any suggestions how to take these out please?
Secondly, that mobile mechanic deserves life time sentence!!! As he replaced the stretch bolts with normal 12mm size very big threaded bolt's. He has also damaged good 1" of the threads of heilcoil. I know stretch bolts are very important but guys is there a way to actually replace them? Is it possible? Or what should be done ? Suggestions please?
Lastly, this heavy smoke indicates bad injector. My doubt is cylinder 3 or 4. Shall I get them replaced? Or get them refurbished? Suggestions please?
Thank you very much for your time guys and I hope so see some genius ideas now.
Regards.
Regards.
