Swapping M104 in W114 Coupe. Is dual fuel pump a must in M104 E320?
hismajestics
Finland
250 CE -72 M104 3,2L
The original setup for W114 (250 CE) uses one fuel pump.
In a W124 E320 the fuel is supplied by two fuel pumps.
Is it absolute necessary to install this setup in my swap or can I use the existing one that is bolted on to the chassis already?
The later 104 engines used just one high power pump.
My late 1995 E320 coupe has just the one pump.
Hi, do you happen to know parts number or something to identify your pump? I would like to compare with mine. Thanks.
