Toilet seat advice
D
Deleted member 113659
Guest
I've been meaning to ask for a long time.
We have an Egg/pod style toilet in our main bathroom. The plastic seat has gone a really off white colour (see pic). It's only ever been cleaned with heavily diluted
Bathroom cleaner so not sure why it's gone this colour.
I've tried many times to source a replacement but so many differing shapes and sizes it's an impossibility.
The seat is a good quality one, really sturdy and soft closing. Can anyone advise of a solution to bring it back to life?
Plastic paint?
Powder coating?
Body shop spray paint of some kind?
Other?
Whatever I try it needs to work because I think I'll only get one chance at this. I don't want whatever I put on it to start flaking/pealing in the future as that will look worse than it is now.
TIA
ANT. :thumb:
Change it's colour to one that matches other stuff in the bathroom - make it a feature rather than a mismatch.
There are lots of specialist paints that will adhere.
That's probably the cleanest reply you'll get on here about a bog seat.
Yes John, it did cross my mind. I'm thinking the usual suspects here will have a few punchlines ready. :crazy:
I agree, I'm not necessarily wanting it white again. But I was more asking for advise on the best route to go regarding paint (DIY or body shop) etc etc.
Have you tried good old T Cut?
Good idea. I'll try the underside of the seat as it's also gone the same. :thumb:
They can't help themselves - but try not to get too bogged down as it's not good for your sanitary...
they can't help themselves - but try not to get too bogged down as it's not good for your sanitary...
b l a s t o f f ! :d
Wrapping the crapper might be a good one :D
PVC cleaner might work, brought my porch up a treat, T-Cut might also work, worth a try anyway Pal:thumb:
After you try T-Cut on the underside of the seat let us know if you are flushed with success.
I had one of those dated '80s pine toilet seats.
Gold Hammerite wasn't much of an improvement, tbh.
The off colouring might be the result of exposure to UV light - what type of light bulbs do you have in your bathroom? And do you have a window?
Also, can you identify the make (and better still the model) of the seat?
Thank you Mark. :thumb::thumb::thumb:
10 LED GU10's cool white in the room and 4 Windows. I assume it's the sunlight that's done it.
Toilet is a 'Vieany' branded. Bought from Spain 8 years ago. :doh:
