darkchild101
- Mar 27, 2013
- Mercedes C250TD
removed instrument cluster to try fix problem where it works sometimes and not others. I put it back in and problem still persists.
More urgently after putting it back in some warning lights are staying on and not going out after ignition e.g brake pad wear, ABS, coolant and oil warning lights. What could be causing this. I know there is nothing wrong with these systems and only came on after i took out cluster and put it back in
