Tool of some sort
Look like the tool you use for pulling out the instrument cluster on 190e and w124 ? Don't know what other models they can be used on ?
Interesting mines a W204! Why store them under the spare? Should be at home in the toolbox hahaha
Used in loads of models for pulling vents too.
Elaborate on pulling vents!!
Some centre vents in the Mercedes require these tools to take off the vent cover. For example, in the W211 the centre vent has 2 tabs located in between the slots. This tool slides inside the vent in order to push down on these tabs and allows you to pull the vent cover off.
Ah ok, thanks for that. Is that what the two little rubber stoppers cover, where the screen cover flips up then. I will need these to fit my ipod interface then yes?
These can also be used as Butt Scratchers, as well as other things. Best used (as above) for pulling out the cluster.
