Transmission leak - advice please
Discussion in 'AMG Lounge' started by RickMM, Dec 5, 2016.
  1. RickMM
    RickMM Active Member
    90
    Feb 26, 2016
    Car:
    C63 Saloon
    Wasn’t sure whether to post this here or in the technical section. I have searched and didn’t come up with anything but happy to be directed to the right place if I’ve missed something.
    Late 2012 C63 just been in to main dealer for B service (45k miles). The video report shows that there’s a slight leak from a hose where it joins the transmission oil cooler (presumably not too big a problem to deal with?). However, there’s also a quote “larger leak from the rear area” (cue the schoolboy jokes :rolleyes:) which seems to be coming from the transmission again. It’s not clear exactly where this second leak is coming from, but the dealer has said that they would need 5hrs labour to diagnose the problem by dismantling the gearbox ! The tech suggests that it may be coming from the main seal between engine and gearbox, although it looks as though it might just be from the transmission pan/filter gasket underneath. These were rated as "amber" rather than "red".
    I guess I’d just like to know whether these issues are common, and what the usual remedies entail?
    The car still has Tier1 warranty, but the service rep said that seals are not covered (assuming that’s what’s leaking). So the story is that I’d have to front-up the initial 5hrs labour to enable them to diagnose, and then they would try to get this sorted under “goodwill” from MB (don’t know how likely that is?). As things stand, they've suggested that I bring it back in 1000 miles for a further inspection.
    Interestingly, there’s been no previous sign or warning of this (tranny works fine) and not a drop of fluid to be seen where it’s regularly parked, although there did seem to be quite a lot under the car on the video.
    Any help appreciated :thumb:
  2. whitenemesis
    whitenemesis Hardcore MB Enthusiast
    12,760
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2016
    Possibly the pilot bush leaking? Do the later 'boxes suffer the same way as the older 5G units?
    1 person likes this.
  3. C63RAA
    C63RAA New Member
    5
    Mar 7, 2016
    Car:
    C63 Estate 2013
    Had a similar problem on mine (2013 C63 wagon 26.000 miles). They found it when it was in for a service. Booked back in got it back two weeks later they had to take the engine out. Fortunately it was under warranty I hate to think what it cost.
  4. markjay
    markjay Hardcore MB Enthusiast
    14,658
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 Retrofitted by www.comandonline.co.uk
  5. OP
    OP
    RickMM
    90
    Feb 26, 2016
    Car:
    C63 Saloon
    Thanks Markjay,
    A second opinion is always a good idea. MSL in B/ham is probably easiest for me.
    However, if it does come to having to get something major done, then it's a gamble between cheaper indy prices versus the chance of getting a goodwill gesture from MB via a main dealer!
    Hope it doesn't have to be either :(
  6. DSB SL AMG
    DSB SL AMG Hardcore MB Enthusiast
    1,599
    Jan 28, 2010
    Cheshire
    Car:
    300SL (R129 1992 pre-facelift), Volvo V70 SE D5 Auto Geartronic
    MSL would definitely be worth a second opinion, can you post stealer technician video report link of issue...?
  7. OP
    OP
    RickMM
    90
    Feb 26, 2016
    Car:
    C63 Saloon
  8. DSB SL AMG
    1,599
    Jan 28, 2010
    Cheshire
    Car:
    Link works fine:thumb:...noticed an error at the end, he missed ''the money extraction team'' will be in contact with you shortly:rolleyes:
    Am sure others will comment on the leak...
  9. fordgt40
    fordgt40 Hardcore MB Enthusiast
    200
    Mar 31, 2011
    Car:
    C63 AMG estate
    I had a gearbox leak after a B service on my w204 C63 it transpired it was because they hadn't fitted the gasket correctly after taking the gearbox pan off, it took 2 visits to cure it , they never admitted responsibility, I will not insult your intelligence as to the excuses I was given as to why it happened.
  10. OP
    OP
    RickMM
    90
    Feb 26, 2016
    Car:
    C63 Saloon
    Interestingly, having been told by the MB service dept that this issue is NOT covered under the warranty, I've just checked the wording in the warranty document and it states:
    "Also included are: Crankshaft front seal, camshaft oil seal, auxiliary shaft oil seal, gearbox rear output seal, drive shaft seals, differential pinion seal and any oil seal or gasket where removal of the engine, gearbox or differential/drive unit is essential in order to effect repair."
    Surely this must include the offending parts here? (except maybe sump gaskets)
    Am I being fobbed off ?
  11. Steveml63
    Steveml63 Hardcore MB Enthusiast
    487
    Jun 6, 2015
    Sunny Abu Dhabi
    Car:
    ML63 AMG
    Yes!!!
  12. DSB SL AMG
    1,599
    Jan 28, 2010
    Cheshire
    Car:
    More than likely...rather than by phone, i would print this section of the policy and pay Mr Stealer Service Dept a visit regarding warranty claim...
    Note warranty claims are agreed fixed fees with MB, obviously outside of this they can charge standard stealer rates direct with the customer...
  13. OP
    OP
    RickMM
    90
    Feb 26, 2016
    Car:
    C63 Saloon
    I might just do that. Thanks for the support :thumb:
  14. markjay
    14,658
    Jun 24, 2008
    London
    Car:
    If the dealer replace the sump gasket under warranty then they may want to re-use the ATF (ie drain and collect, then use same ATF to refill).
    In this case I would be inclined to pay for new MB ATF (possibly also filter?) and have a partial ATF change/refresh (ie not including the torque convertor and transmission oil cooler).
    But this is of course down to when/if the ATF was last changed and how long you intend to keep the car.
  15. OP
    OP
    RickMM
    90
    Feb 26, 2016
    Car:
    C63 Saloon
    Got stung for the ATF change 12 months ago at the last service, so all should be good there?
    I also had the AC condenser changed under warranty about 4 months ago, and there was no mention of any oil leaks at that time.
    Plus, there's no sign of anything having dripped onto the drive where it's parked, despite what looks like quite a bit of oil under the car in the video (link above) :confused:
  16. Steveml63
    487
    Jun 6, 2015
    Sunny Abu Dhabi
    Car:
    ML63 AMG
    I would be inclined to try and clean all the oil off and see how long it takes for some more to appear.
    That will give you an indication of how bad the leak is - and confirm whether the dealer is pulling a fast one (putting oil on outside of transmission to masquerade as a leak!).
    Cheers
    Steve
  17. Captain Smerc
    Captain Smerc Active Member
    89
    Apr 16, 2014
    Barter Town
    Car:
    C63
    My 2012 model had this issue , it was spotted at service time . Fixed under warranty which had only a week left ! Said they had to drop the gearbox out . Got it back inside 2 days , good work MB Southend :D
  18. OP
    OP
    RickMM
    90
    Feb 26, 2016
    Car:
    C63 Saloon
    This is what I'm being told at the moment (drop and strip the gearbox to diagnose the problem) although initial comment was that "seals" are not covered under warranty.
    I think I might have to disagree... or go to a different dealer !
Share This Page
