i have a c270cdi (2003), when starting the car from cold it fires up and cuts straight out, it will only start after several minutes of turning over, she will then fire up and run perfectly all day starting first time as should there on after,
i had some leaks around the pressure pump which i replaced the pump and sills, i have also replaced the glow plugs, it still wont start.
during milder weather and during the summer the car starts first time from cold as it should do, its only in colder weather.
can anybody advise what could be causing this please.
many thanks
many thanks
