what you guys think, i think its a beast!
https://youtu.be/BSGZKcQ9ktk
It'd be interesting to know costs as that would certainly be better than supercharging in my opinion.
Better in what way?
more power mabye?
Better in what way?
Deff more low down power than a charger. Bet that's a beast !!
Supercharger has all the power from low revs.....you have to wait for turbos to spool up.
Twin turbo on M156 is not new.....Branus did one years ago.
Will be interesting though to see power figures and how tuneable it is ( the super chargers run low boost....8psi)
more power mabye?
More mappable than a supercharger and more upper end performance. Obviously some negatives to consider such as heat, but I always preferred a turbo over a s/charger.
I can see another advantage to turbo, being able to ramp up the boost pressure per gear, configurable power, lower boost in lower gears aids traction meaning more usable power to the road, as you gain traction increase the boost pressure, usually the higher gears, not so much modulation of the throttle required.
Yes, and inlet pipework too long = turbo lag (a pet hate of mine).
Give me a belt-driven supercharger any day.
Plus, there's really no such thing as "free power"!
I will tell you that the car makes over 600WHP on 93 octane with less than 6 PSI of boost. We have high expectations for this car. The motor is built and has lower compression pistons and upgraded rods. We will be testing the limits of the fuel system over the next few weeks.
As you can see in the video, our Dynojet does have LOAD control and is a linked AWD dyno. This means that the 2wd C63 was actually measured while all 4 tires were spinning on the rollers.
