Rears in particular are too high unless you are driving around fully laden at high speed all the time.
I run my E55 on 18s at 35/35 and that is heavier than a CLK.
I'd drop to the suggested 31/31 like your fuel cap shows.
I thought as 44 is shown on bottom for 4 pas, 130+ should be safe to fill to that? Will reduce it anyway but shouldn't be dangerous should it? Maybe use more fuel/increase tyre wear?
Cheers
You have to try it.
I ran the W203 on the higher figure in the range and it felt just right.
I tried the same on the W204 but it was very bouncy - it seems much happier at the lower figure in the range.
Incidentally... in spite of the suitcases, you can run the car with the pressures within the range to suit your driving style even if the car is not fully loaded - that's official.
The higher figure in the range is for generally more sporty feel and also for motorway driving. Not only for when carrying heavy load.
Yeh the car seems a lot more boucny on country roads but a quick motorway blast it felt better than before..
Decisions decisions
This might not be of much assistance... but Russian ZIL trucks had a tyre pressure system that allowed the pressures to be changed from the cabin by means of an engine-driven pump feeding the tyre through the hub. Great when moving from mud or sand to paved roads and back.
Standard on US military spec Hummer H1. I believe it can be ordered on some new Hummers.I'm sure I've seen that on other 4x4s as an after-market accessory.
If we are being pedantic and need tyre pressure to remain as close to cold setting the tyres should be filled with Nitrogen gas.
I thought Nitrogen fill was about leakage rates and freedom from moisture content. Nitrogen still has to obey the gas laws so pressure will rise with temperature Approximately 0.1 bar for each 8 Deg C rise.
