planetdrew
- Nov 28, 2014
- Mercedes Sprinter 416CDI 4X4 LWB HR Crew Van
I own a Sprinter 416CDI 4X4 LWB HR Crew Van which has 5" x 15" rims currently shod with 195/70 rubber (twin wheels on the rear).
I want a higher profile tyre & want to know what tyre I can use?
I need to consider:
1. The tallest tyre possible to give good ground clearance & slightly better gearing.
2. It needs to be a common size, so it’s easy to get spares in the future.
3. As well as being tall & common, the tyre also needs to be able to cope with the weight (Approx 3500kg)
4. If the tyre is too big (tall or wide) it might rub on the body or chassis on full lock or on full articulation.
5. As well as all these factors it needs to be a decent tread, like an All Terrain.
Any advice is welcome!
I need to consider:
