T
tanuie
Guest
Any one had any excelon tyres, i realise that they are budget tyres, just wondered what they are like.
Make sure your will is up to date
Budget tyres I've used are Falken and Fulda, which give a good performance to price ratio - which are fine on a standard saloon.
Though not sure if I'd fit them to an AMG if driven in anger.
The stopping distance difference at motorway speed on budgets vs. Premiums is several car lengths.
I have, and they are absolutely fine. When you start reaching silly speeds you need to be able to trust the tyres you are using. I have no fears using Falken ZE914's
Edit....... I wouldn't class Falkens as budget either. Mid range price yes, but not budget.
The thought of people fitting the like of Kumho, Nexen and Wanli fills me with enough dread, let alone these white label jobs.
Did you know Kumho are one of the brands MB are fitting on new cars now in the show rooms?
And MB will be rubbing their hands on what they are being paid to do so. Doesn't make it any better a tyre though.
Yep, they are a white label tyre from China for the Itochu Corporation....
Would be interesting to see new cheaper tyres vs. worn (say 3mm) premium tyres .......
Yep, they are a white label tyre from China for the Itochu Corporation. Just a different side wall moulding to many of the other white label tyres from factories over there producing cheap tyres from purchased old technology.
I had Kumho on my M3 when I bought it. They went out of shape and basically fell apart after some hard use.
Off they went replaced by four Michelin Super Sports. Chalk and cheese difference.
I've seen results from this kind of testing, unfortunately I can't remember much about the results however, from the tests I go with worn premiums anyday.
Do hope your not suggesting Kumho purchase their technology, like some. Whilst I've gathered you've had a bad experience with Kumho, as mentioned on a different thread they out perform Verds. in many curved tests, however, The Verds will cover more miles due to the harder compound..
Good that we all experience different things in life, I'd go for Kumho's over Mich. anyday. We have had so many problems with Mich. over the years starting with them not been in balance and round to start with and then becoming misshaped together with their wet weather issues they are no longer considered, guess it depends on driving styles..
