nigel cross
Has anyone successfully unlocked one of these to work on a different network apart from 02
Probably easier to use one of those magic SIM cards that wedges on top of your actual one.
I am looking for Jailbreak and Yellowsn0w - but can't seem to locate it.
Can I ask whats the benefit of unlocking it to vodafone? will the internet 3g still work?
Try contacting your service provider.
How's it done through iTunes?
Pontoneer said:Simple : after O2's monopoly in the UK was broken , Apple enabled unlocking to take place through iTunes , even on brand new phones still under contract ( this does not mean that you can get out of a contract , but you can enable the handset to be used with any SIM ) .
Just launch iTunes with the phone connected and first of all let it sync so that all your content is backed up .
Then , select the phone under the 'Devices' tab on the left hand side of the screen , and select the 'Summary' tab at the top of the page .
About halfway down the page , select 'restore' which allows you to restore the phone to factory settings .
Let the phone run through the full restoration proceedure which takes about 15 minutes - at the end you will have a message 'Your iPhone is now unlocked'
You can then put in your new SIM before setting the phone up and then restore from your earlier back up .
I have unlocked three iPhones this way - it works .
