Valve Covers.
T
tanuie
Guest
I went to the Garage to check tyre pressures and found with the chrome valve stem covers, the air hose would not go down far enough to inflate the tyres,
so after removing the said valve covers all was ok. I have had a few Mercedes and this is the first time this problem has occurred. So i think that they are a good idea, but be warned.
Sounds like you have 27mm stem covers on, when you actually need a 20mm version?
Thanks, answered on other side.
