Vito Sliding Door Won't Open From Outside
Discussion in 'General Discussion' started by Arthur13, Dec 28, 2015.
  1. Arthur13
    Arthur13 Member
    42
    Nov 29, 2015
    Wiltshire
    Car:
    Vito 109cdi 2007
    My 2007 Vito has a a few annoying issues which i want to work my way through!
    One of which being the passenger side sliding door doesn't open from the outside,
    When i unlock the van with the fob the door doesn't open from the outside, and if i go in the back and try open it, the door opens! so if i then close it and open it from the outside it will open no problems until i lock and unlock the van again! occasionally it will open from the outside after unlocking but its pain!
    What do i need to do?
  2. ash59fifty-uk
    ash59fifty-uk Hardcore MB Enthusiast
    2,866
    Aug 9, 2015
    The shire
    Car:
    W204 C200 CDI Sport, VW Transporter
    Wildcard answer but on the inside of the sliding door there isn't a latch/button resembling a sort of reverse child lock is there?
  3. OP
    OP
    Arthur13
    Arthur13 Member
    42
    Nov 29, 2015
    Wiltshire
    Car:
    Vito 109cdi 2007
    I will check in the morning, thanks
  4. Vitobrabus
    Vitobrabus Active Member
    64
    Nov 24, 2014
    Car:
    Vito Sport X
    Sounds like the unlock part of the central locking isn't working on that door. Vitos don't have deadlocks so it will always open from the inside. Try cleaning the contacts on the forward pillar
    1 person likes this.
  5. Vito V6
    Vito V6 Member
    40
    Jul 8, 2014
    London
    Car:
    Vito V6 W639 2009 Auto (120CDI)
    Hi, did you manage to fix this?
    I've got the exact same issue however mine started after someone tried to break in through that door so handle was bit damaged!
  6. ceselec
    ceselec Member
    38
    Jun 28, 2016
    North Yorkshire
    Car:
    Discovery Sport, Vito W447
    My last vito did this after I tried to open the side door when it was frozen shut, turned out that I had strained the rod / mechanism from the handle
Share This Page
