VW Polo headlight bulb AAAGGHHH
Discussion in 'MB Defectors to Other Marques Forum' started by Smiley, Nov 1, 2008.
  1. Smiley
    Smiley Hardcore MB Enthusiast
    2,021
    Jun 29, 2008
    I have today replaced the offside headlight bulb in my wifes 2006 Polo. I thought it was going to take 2 minutes - ended up moving the car into the garage as it got dark. Unbelievable - had to remove fuel filter housing - which itself was a bit of a devil because of the location of the mounting bolts and even with that obstruction out of the way it was a struggle with a lead light to see what I was doing behind the headlight. I had to use a socket set ratchet plus extension bar, flexible joint, T40 torx socket, screwdriver; all to change a bulb!
    I love my W124!
  2. Dunhamkid
    Dunhamkid Member
    52
    Oct 18, 2005
    Cheshire
    Car:
    2007 W251 R320 CDi
    Had the same problem changing side light bulb on 2003 Polo. Found it easier to remove the bumper (30 minutes work), remove light units and replace both bulbs at the same time, but must admit, it is a pain
  3. rf065
    rf065 Hardcore MB Enthusiast
    2,873
    Jun 8, 2007
    Grossbritannien
    Car:
    CLK 220CDi - SLC300 - C250d Estate & VFR 800Fi-1
    I had to do the same for my W209 CLK, so not just VW at fault here.
    Russ
  4. CE230
    CE230 Hardcore MB Enthusiast
    574
    Sep 10, 2008
    Wylde Green
    Car:
    230CE
    Wifes Rover 400 is just as bad, unless you have the hands of a 5 year old.
  5. del320
    del320 Hardcore MB Enthusiast
    1,759
    Mar 4, 2005
    Near Melrose, Scottish Borders
    Car:
    1996 E320 Coupe
    Nothing new here - I seem to remember BBC Watchdog did a piece on the last series, reporting that a Megane required around two hours labour dismantling the front of the car. :crazy:
  6. OP
    OP
    Smiley
    2,021
    Jun 29, 2008
    I looked at that optin as well and started to remove the grille but it is all one big piece (mine is a 2006 model) - for interest next time how does the bumper come off?
  7. stevesey
    stevesey Hardcore MB Enthusiast
    2,968
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    Fifth Gear as well - circa £100 for dealer to do it wasn't it, I think the RAC guy they got in took 40 minutes or so.
  8. crockers
    crockers Hardcore MB Enthusiast
    7,097
    Mar 30, 2007
    North Wilts
    Car:
    XC60 MY2014 SeLux Nav plus lot and lots of toys...
    On my wife's Honda I had to open the bonnet.....................:D
  9. OP
    OP
    Smiley
    2,021
    Jun 29, 2008
    Exactly what I was expecting to do with the Polo. By coincidence the tail light bulb went in the W124 estate today; it was the nearside so I did have to take out the spare wheel, must have taken a total of 2 or 3 mins max.
  10. A-AvantGarde
    A-AvantGarde Hardcore MB Enthusiast
    4,606
    Nov 11, 2003
    South Bucks
    Car:
    2014 BMW F06 640d GC, 2007 Volvo XC90 3.2 (no Mercs at the mo!)
    Fiat Stilo is like that too, tried to help my bro-in-law with changing some headlight bulbs, turns out it's a bumper off job :eek: Thought it would be really simple, or at the worst a lights out job (like the MK2 Ford Focus) Apparently Fiat dealers were told to do bulb changes free of charge...
    Even the rear lights on the Stilo need the light cluster to be removed (although the W163 ML has that flaw too!). At least Merc make it easy to remove the rear light clusters, on the Stilo it was a pain in the :eek:
  11. Dunhamkid
    Dunhamkid Member
    52
    Oct 18, 2005
    Cheshire
    Car:
    2007 W251 R320 CDi
    Not sure if method is the same but remove grill item with badge on and the two lower air vents. Each side of wheel arch there are 4 torx screws to remove. Along bottom of bumper there are 8 torx screws and 4 plastic clips. At the front of the car there are several torx type bolts to remove (hidden behind the black plastic trims that have been removed). There is also an electrical connection to disconnect, not sure what it was. Pull away the bumper at the wheel arch end (it should have slots to hold it in place) and remove. The rest is plain sailing!! Need 2 pair of hands to replace, watch out for the slots on the side when refitting the bumper. I put the car on ramps to make access easier, no need to remove wheels. For info, the bumper removal was very similar on a 1996 Polo
  12. gurpz
    gurpz Administrator Staff Member
    3,724
    Jan 28, 2007
    London
    Car:
    Mercedes C230K Sport
  13. BTB 500
    BTB 500 Hardcore MB Enthusiast
    16,993
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, 639 Vito 120 Dualiner Long, S203 C230 Avantgarde SE Sport
    Yup to do the offside one on my wife's Audi A4 meant taking apart the engine air intake etc. to get to it (the handbook did guide you through this though). The nearside one was a doddle.
  14. OP
    OP
    Smiley
    2,021
    Jun 29, 2008
    The Polo handbook just says take cover off bulb and replace :eek: . Then recommends taking it to a dealer as there may be some sharp edges that could cut your hand. How pathetic is that? No mention that you can not even see the cover let alone get to it! And no mention of the two small torx screws holding the headlight retaining bracket in place - which on mine had obviously been incorrectly fitted before because the bracket just fell out....I am tempted to go and look at a Honda Jazz or Toyota Yaris - everything I look at on the polo looks like it is difficult to do / get to - like getting the undertray off involves about 15 torx screws in slightly awkward locations. Maybe it is just a feature of newer cars - my next newest one is 8 years old.
  15. crockers
    7,097
    Mar 30, 2007
    North Wilts
    Car:
    Have to admit -- I have never checked a car before buying to see how easy this is... I'm lucky that the W203 and Honda CR-V are a doddle....but if and when we change either I will now always check this.
  16. BTB 500
    16,993
    Aug 7, 2005
    Berkshire
    Car:
    I replaced all the headlamp bulbs in our vehicles with the Philips X-Treme ones ... so I did all of them in one go.
    The SL was a doddle, the Vito was a bit of a pain (H7s ... so 4 bulbs rather than 2), and the Audi was a real pain!
Share This Page
