W123 300D Air Con Condensor Radiator replacement
Screwdriver
Greetings,
My original air con condensing radiator on my 1984 UK 300D has sprung a leak. MB UK no longer sells a replacement so I'm going to have to turn to an OEM supplier. The dealer shared the following part number: A1268300670. I believe the original was made by Hella-Behr?
Any suggestions on where I can purchase one?
Many thanks!
I'd prefer to save that as a last resort option if possible. It will likely cost the same amount to procure a new unit, like this Hella condensor sold on Ebay
All I need is confirmation that it will fit (I've asked the seller today).
Received following confirmation from the seller that this is the correct part:
8FC 351 035-751
HELLA Condenser, air conditioning BEHR HELLA SERVICE
Chassis no. from: 133346
Length: 517 mm, Width: 416 mm, Depth: 32 mm, Outer diameter 1: 16 mm, Outer diameter 2: 22 mm, without dryer
