The ASD light (lower right hand side of dash) has been on for a few weeks now.
It used to come on for an hour or so after a car wash and then turn itself off. The last time this happened, each time I pressed the brake pedal, another light would come on in the middle of the dash too. Now the ASD light stays on all the time.
I found some threads which describe using a wire between terminals 1&5 in order to get a flashing code to locate the fault, but the light still stays on and there is no flashing. I really dont want to just go out and get a new ASD relay as they are expensive, but is there anything else I can do to get the diagnostic to work?
