That`s correct mate but do it once,I would not bother with the one on ebay
The large nut on the coupling is a left hand thread [ it should have small cut marks on the edges of the nut flats to signify this] you will need a a large water pump spanner to remove replace it. e.g. Halfords | Laser Fan Spanner 32/36mm
Got the spanner. Simply undo the nut and that's it? Or there's something else holding it?
Then the coupling is held by 3 hex screws, right?
Undo the nut remove the fan + coupling. undo the 3 allen head screws- remove plastic fan and mate it up to the new viscous coupling.
Where you may have difficulty in locking the water pump pulley to undo the nut [anticlockwise] A crude way is to lock it with vice grips to prevent it rotating- MB has a special shaped key that fits over the the water pump pulley allen screw heads
How much is that special tool from MB? I struggled to undo the bloody nut, despite whatever I tried The water pump keeps going round, and I can't stop it, lol
TOO expensive - even if you can order it now . I made one from some 1/8" mild steel plate. Made a template from stiff card first [ breakfast cereal packet is ideal] then scribed the cut out shape from there. Used a drill of correct size for allen screw heads and jigsaw with a suitable metal blade for the rest.- make it with a long handle on it!
Top tip here..
Get the spanner and give it a hard smack in the correct direction with a hammer,,it will come off no probs..
Will give that a try, cheers
By the way, undoing is anti-clockwise, correct?
