W124 E300d OM606 fault find question.
Discussion in 'Engine' started by Charles Morgan, Dec 28, 2016.
  1. Charles Morgan
    Charles Morgan Hardcore MB Enthusiast
    8,030
    Feb 2, 2010
    Car:
    Mercedes 250CE W114, Alpina B3 Cabrio, Alfa Romeo GT Coupe 3.2 V6
    After replacing the glow plugs on my OM606, recently on start up the following has been happening - ABS warning light on, Rev counter stuck on 0, and idle too weak to move the car when in gear. This is intermittent but becoming permanent. It either all happens together or no faults at all.
    Just checked the fuse on the OVP relay which was fine (but will be replaced anyway).
    Any other suggestions to check?
  2. roadhog
    roadhog Hardcore MB Enthusiast
    158
    Jan 21, 2011
    Norfolk
    Car:
    '93 W124 300D x2, '89 C124 300D, '95 A124 320CE
    Maybe the OVP relay itself? A functioning fuse does not necessarily mean the relay is ok.
    Have you checked your alternator output? I've had two fail in my time, both times the first symptom was the ABS warning lamp. The rev counter is a voltmeter I believe, maybe your battery is sucking up what little charge there is available from an ailing alternator?
    1 person likes this.
  3. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    The battery is not in the best of shape but was fully recharged before I fired her up. I'll check the OVP relay.
    Another suggestion made elsewhere was the loom might be in poor shape, which is certainly the case with the glow plug relay loom.
  4. grober
    grober Hardcore MB Enthusiast
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Another vote for the OVP ABS light is a classic fault indication OVP supplies abs controller, engine ecu and motorised rotary fast idle valve [ on petrols at least] the soldered joints crack with vibration
    Numerous guides how to resolder them online.
    here's one.-- other guides may be available.;)
    [YOUTUBE]/zPSSXSVMiJk[/YOUTUBE]
  5. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    My old skills have returned. Removed the OVP relay, cleaned all the connectors, removed the metal shell, re-tinned the connections as per the vid and lo, the car now won't start and the ABS light remains on...
    My initial thought is the loom is the likeliest problem. Getting the OVP relay in and out of the connector required a fair bit of tugging.
    Starting to think the car needs to be disposed as it has far too much to do to get it running, even before all the work on the body required.
  6. grober
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  7. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    Thanks Graeme, I'll have a check to see if it is the OVP relay at fault.
  8. brucemillar
    brucemillar Hardcore MB Enthusiast
    6,477
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    let me know if you wish to test with my OVP. My car is laid up for winter.
  9. grober
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  10. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    Tested just now. The relay is clicking away intermittently but testing the pins as per the link above, the highest voltage I got was 2.4 on one. So the OVP (or my testing) looks faulty.
  11. grober
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  12. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    That will be the next thing.
  13. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    Very kindly indeed, Neilrr just popped over with 4 OVP working relays so I can test away with enough to be certain whether it's the OVP or the car. The forum at its finest!
    2 people like this.
  14. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    Success! First OVP relay in and it fires up, idles properly, rev counter works and ABS light gone. Many thanks Neil!
    So now to get all the manifolds back on after changing the glow plugs and get the car back on the road.
  15. grober
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Result! Might be worth getting your alternator output checked at some point as a precaution?
  16. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    Is that something an electrocution prone idiot with a cheap Chinese multimeter can do or should I get someone else to do it?
  17. brucemillar
    6,477
    Nov 18, 2010
    Car:
    Charles
    Easily done (even by my accident prone standards). You should be seeing (Volts DC) 14.x across the battery at 2.5k rpm. This would then drops to 12.x at idle and further drop to 8.x when cranking.
    On my 300te the brushes failed (they were 30 years old). This was evident by fluctuating voltage seen in the headlights (bright to dim) and on a volt meter across the battery. New brushes are available from ebay for about a tenner. Have a look at your alternator and see if the brush pack unscrews from the rear. On mine it was two phillips screws, visible from above the car and reachable with a stubby driver.
    If in doubt it is worth a try, as when they go, they are dead and they will always fail in heavy traffic, at a major junction, with a fire engine on blue lights, trying to get around you, in the pouring rain.
  18. grober
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    My concern would be for some form of AC or voltage spike breakthro damaging the zener diode/s in the relay. However your OVP may have just died thro old age.:thumb: These basic voltmeter tests should reveal if anything is wrong.
    [YOUTUBE]LGB6ZEjGm7Q[/YOUTUBE]
  19. OP
    OP
    Charles Morgan
    8,030
    Feb 2, 2010
    Car:
    Can't get it up to 2.5k on my own, but at 1.5k it is putting out 14.3, and at idle 13.5v (the battery has been fully recharged though last night). No fluctuation on the voltmeter.
  20. grober
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
Share This Page
