I have read that corrosion may occur around where the hard metal fuel line is clamped by the mounting brackets around the rear axle going to/from the fuel tank. Does anyone have any pictures that show these corroded fuel lines?
If they do corrode here, what are the options to repair? Do most people replace only the corroded section with rubber fuel hose or copper pipe, or will it require a complete new line from the engine to the tank?
Many Thanks
Many Thanks
