I daily drive a 1987 300ce with just over 40k miles. Since I bought it a year ago, it's had a slight shake at idle when in drive or reverse. The revs do not fluctuate, but every second or two you get a slight shake from the engine that's felt through the body. The car also jolts when shifting from drive to reverse. It idles pretty much perfectly in Park or Neutral, and drives surperbly.
To try and improve things with the shake (and also just as preventative maintenance) the following parts have been replaced with new items:
Plugs
Plug wires
Fuel Injectors and seals
Over voltage protection relay
Idle control valve
Distributor cap
Rotor arm
Fuel filter
One of the problems I have with trying to diagnose the issue is the mileage of the car. With only 40k miles and having been garaged for the vast majority of its life, everything in the engine bay looks very fresh, with parts such as vacuum lines and bushes showing no evidence of cracking etc. However, given its age and how rarely the car was used, many parts seem to have dried out and hardened up despite looking as good as new on the surface. A case in point was the anti roll bar bushes. Looked perfect, but replacing them and the associated brackets totally silenced the squeaky suspension on cold mornings.
As such, I was wondering what you all thought about my prospects with changing the engine and transmission mounts in terms of reducing vibrations?
Again these are rubber parts filled with fluid that on the surface look perfect and everything I've read suggests they shouldn't need to be replaced until well over 100k miles.
Basically should I be ignoring all the mileage guidance on the longevity of parts, due to the fact that the car is now 28 years old?
Plugs
Plug wires
Idle control valve
Distributor cap
Rotor arm
Fuel filter
