brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Guys
On my 124, I occasionally lose all speaker output? It is almost as if the radio has been muted!! All speakers just stop, nothing, nil, zilch, not even a background whisper of hiss.
I know that this is not the head unit as I have the same issue with other units I have tried (and they are different makes).
There is no pattern to when this will happen. It just does. The latest episode is with the car sat on axle stands in the garage > radio playing and then >>>> Nothing, silence. The head unit stays correctly illuminated and displaying the station etc. Switching to a CD has no effect. We remain muted.
I currently have the car playing only via the front dash speakers. The wiring to these, is the stock MB wiring that has not been changed, with the small blade plugs in each channel just behind the head unit.
There is a mute wire (white) on the Euro Connector. I have taped that and ensured it is not shorting.
I also have the fade wheel for the rear door speakers. This is not in use as these speakers are disconnected for testing.
When it is working! It is absolutely fine. Then with no warning or movement it will just cut out and can stay like that for days only to return when it feels like it.
Any suggestions?
I am thinking an earth problem. But how to test this?
It has been suggested that the electric antenna may be a weak spot, but could this mute the speakers?
I am more on the side of this actually being a mute action, given how it only cuts the speakers and all media, CD, Radio etc.
Any suggestions?
