MantaOwner
Hi all, it's my first post here, hope to spend some good time in this forum.
I have a 1994 W124 E220 sedan A/T. Got some questions.
1) Combination switch doesn't turn on high beams when you pull it towards the steering wheel and hold it, what can be wrong? All other functions (wiper and turning lights work fine, also high beams stay on when the switch is pushed away from the steering wheel) are ok.
2) How to change (how to get to) the small bulb that lights the left air vent above the main light switch in the dashbord? My car has the driving wheel on the left side as we have a right hand side traffic in our country.
3) The biggest problem - sometimes the starter doesn't get power from the ignition switch when the key is turned, I've then mechanically connected two "+" wires together on the starter for a moment until the engine starts. I know that the "+" wire runs from the ignition switch to the reverse switch connector first, where is this connector and how can I get to it? Starter itself is 100% ok. Ignition switch has not been checked yet.
4) I plan to install footwell lights for both front and rear seats, where should I take the signal from? Ideally those lights should work together with the front roof light but it's not convenient to run new wires from the roof to the floor.
Tõnu
Tõnu
